can anybody give me a idea y my 1991 hilux surf keeps overheating and blowing the water out of the headertank have just rebuilt the topend could it be a crack in the water way thanks logman65
1991 hilux/surf import
Could be a couple of things, airlock in the cooling system, or head problems causing the cooling system to presurise, when you say overheat, how bad is it, how much water comes out, is there any oil in the water,Originally posted by logman65 View Postcan anybody give me a idea y my 1991 hilux surf keeps overheating and blowing the water out of the headertank have just rebuilt the topend could it be a crack in the water way thanks logman65
Need more information about exactly what happens.www.furryfriendsinneed.com
So basically when it has to work the engine overheats, could be thermostat,Originally posted by logman65 View Postboilsup going up hill no oil in water fills up headertank and then over flows temp gauge in red
take it out and boil a kettle, pour water into a jug and put the thermostat in, see if it opens.
If not then replace, do a search on here and there is a thread on how to burp the system, next to check is the water pump, behind cam belt cover, if this is alright, then it is probaly head gasket, did you use genuine parts,
are the head bolts torqued correctly, did you use new bolts, need more info on exactly what you did when you rebuilt the topend.www.furryfriendsinneed.com
The header tank isnt a regular header tank,the cap is a two way,allowing water to flow back and forth from the cooling system,allowing expansion.Thats why,sometimes the plastic tank is near empty,othertimes its near full.Try changing the cap.They stop working sometimes.
