hi all i'm thinking about buying a surf 2.4 the problem is it will run no problem for a while then if you turn it off it won't start again untill you leave it for a couple of hours, it's had a new fuel pump fitted ecu tested and all the wiring tested and it's still the same, was just wondering if anyone else has had any similar problems before i buy it, as it needs to be sorted when if i buy it. cheers simon
won't start
Originally posted by oneintheeye View PostTook a change and picked it up today messed with the fuel cut off solinoid and away she went...
Nev
Originally posted by oneintheeye View Postit's on the back of the fuel pump theres a cap on top covering the adjuster screw all i did was adjust it in until it started (it blew lots of smoke) then just turned it back until the smoke cleared hope this helps it sorted mine outRussell
