undefinedundefinedundefined
Hi all,
HAd my surf for just over a year and all is okay - ish !
Its recently started to pour coolant into the expansion tank when hot and dribble it on the floor. Doesn`t over heat and the heaters are both hot. No probs starting and no signs of head gasket failure - I think its just the filler cap seals are not sealing !!
The engine has developed an oil leak under the inlet manifold. The oil is also around the manifold where it joints the head itself. The oil is not dripping on the floor it just coats the left side of the block. Any ideas ?? Is the oil feed up to head on this side of the block ??
One other point, the "power" transmission button does not do anything. Whats it supposed to do and is there a fuse in the circuit anywhere ??
Any help would be much appreciated guys. Thanks, Eddy.
Hi all,HAd my surf for just over a year and all is okay - ish !
