Hello,
Can someone shed some light please?
I had a problem were my 80amp fuse kept blowing for the heater plugs, it wouldnt start or fire without a small dab of easy start in the morning, the rest of the day would be fine. i took that to an auto electrician and he said fuse was blowing because a wire was shorting out near injector.
He sorted it, and you can hear it all working now,
Morning after, give it a few turns heat the plugs, and nothing firing or starting, tried dab of easy start and that found it hard work, its took about 10 mins get it going with easy start,
whats my problem
SURF 2.4TD 1992
whats my problem
SURF 2.4TD 1992
