2.4TD,12/1991, automatic trans Surf
At idle and in gear my Surf makes a wierd chirping/squeaking from the engine compartment. When I look under the bonnet, all belts seem adjusted to the correct tension.
One concerning thing is at the top of the belt drive is a small smooth idler/tensioner pulley that looks like it should ride on the belts (twin fan belts) and it doesn't seem to hardly touch them. I cannot find any adjustment for that pulley and it doesn't seem springloaded.
Can anyone help with a diagram outlining correct belt routing (I am concerned someone has put the incorrect belts on) or does anyone have any experience with this issue?
Thanks in advance,
Thanks in advance,
