Ok, firstly...
Recently a grinding noise, sound like something getting chewed up in fan belts had started to appear. The surf could run weeks without the noise then it would appear out the blue.
I ignored it since was unexplained then it happened more frequently. it comes from the passenger side back of engine bay and will happen either when surf is idle or moving along, I know not a lot of info here and i can't see anything but just wondering....If its coming from that direction [think of it being around the fuel filter] what could it be?? [oh a noise comes and goes, only lasting less than a mintue or so]
Secondly, got home from work tonight, stopped to open drive way gates jumped back into the surf and when pulling away felt a crunching through the clutch pedal. it still pulls perfect just the noise and vibrations through the clutch, once again, possibilites? oh..and for some reason grinding doesn't happen in 4WD.
Surfs runs perfect, no lose of power, no whinings or others, just these little irritatiing noises that are getting to me.
