Hi fella's, couple of questions for the guru's.
1 When selecting heater vent positions nothing happens, however I can hear a click each time a button is pushed, cheching the white plastic linkage in drivers footwell I can see it try to move and a gentle push helps it along. I've dosed it with WD but still no go. What actually operates this linkage?
2 Would the engine bottom pulley still squeal if the V belts were removed, I've stripped the whole front end down (new cam belt) but found nothing wrong, squeal seems to come from front pulley area.
Thanks.
Thanks.
