I was wondering if anybody could help or advise me please.
I have had a small oil leak for a while and know exactly where it is coming from and have tried to fix it by changing the hose and putting a jubilee clip on instead of the previous fixing but this has not worked and it still leaks, I have accepted this because it is a tiny leak and I just wipe the excess oil off reguarly. This however is not the problem.
The other day I had been over to the North East and on my way back stopped at Hexam for some supplies. coming back to the surf our lass noticed a pool of oil under the bonnet, I had a look and checked the oil level and had enough to get home.
Had a good look and noticed that it was right below the air filter where there is a double nut.
Stripped out the air filter and on doing so the air intake pipe had loads of oil in it so I drained and cleaned it up and also the filter housing where the oil had been coming out of the little bladder at the bottom. checked the intake manifold and this was dry and also the pipe coming from the engine block and this also was dry.
checked the double nut and this was tight.
Anyone have any ideas where the oil is coming from and how to stop it????
