Basically my clutch needs to be done , its not slipping or anything yet but it is bighting at the top end of the pedal travel this i know,,
Now the problem i have is, after leaving the hospital today i was driving fine gears changed up 1st 2nd then i could not engage 3rd or 4th but 5th and reverse are fine..???
when the vehicle is staionary still the same problem with motor running or turned off , i can still enage the same gears,,
Anybody got any ideas? i thought its possible the clutch is not depressing enough hence not ebing able to engage etc but i dont think its the case, oh one more thing its a 2.4 turdbo diesel . If i try to engage 3rd or 4th its very very hard to push the knob in the direction of thoughs gears (impossible) . i dont even get a crunchy noise if moving along, Maybe the gear rail has seized hmmm
Anyway and help would be appreciated thank you
