If you've had the rad out and then stick it back in and fill it and run the air out - just be sure you refit the shroud BEFORE you hook up the rad hoses and finish the job.
With everything in place the shroud just cannot go back in place coz the fan is in the way and so is the top hose. Dont try taking the fan mech off the pulley coz you cant get the fan mech back in once the shroud is on. Then dont think it'd be a good idea to take the fan blades off the mech and try and squeeze the mech in thru the pipes coz although it will go in, the fan blades wont follow.
If you did all the above of an early evening you would then spend the late evening taking the rad back out altogether, disconnecting the shroud again, bolting back up the fan mech to the pulley, tensioning the alternator tensioner, then dropping the rad back in again, then fitting the shroud top and bottom sections, and then running out of light and putting the rest of till tomorrow...
I said,"Oh deary me, what have I done, bother!"
