Hi everyone.
After eight weeks in the garage, the problem with the loud knock was finally diagnosed. It was two blocked injector nozzles. Put new nozzles in all four and the knock disappeared. I was delighted any one interested please read Major Head Story then Fault Finders needed.
The garage bolted her back together and she was purring like a kitten, off for test drive of about a mile. Pulled over and there was water pouring out of the expansion tank. The pressure in the rad cap was immense.
I showed up a few hours later. Mechanic started her up to show me and straight from cold the pressure build up was huge.
No sign of water in oil or vice versa. Rad was filled at rad cap, even with no thermostat fitted it pressurised everything.
Garage are saying it must be the head or the gasket, if not then its a porous block.
This nightmare began in January with the cracked head, then a new one was fitted that warped and had faulty injector chambers(loose).
The Head Centre then fitted new oversize chambers and skimmed.
The first road test after 8 weeks sat in garage looking for the injector problem was today and this is what happened.
Now, either UK Cylinder heads are seriously dodgy (anyone know why they ask for heads as exchange items-what are they doing with them?)
The head gasket from Roughtrax is dodgy or my block is U/S.
Does anyone have any suggestions, like airlocks or whatever before I rip head out again and get pressure tested?
Please help me out as this is a total and utter nightmare.
