Timing Belt
    If you don't mind doing that Rich as it will save me a bit of time stripping the clocks down to get it out.Cheers
    not a problem i will get that in the post as soon as i have some postal info
    Show me where the trench is at or can i make one!
      timing belt
      Hi
      Today car overheated again, have changed water pump as garage said it was shot, could it be the head, I'm going to use something called steel seal has great write ups, if that don't work will have to strip head and check, fingers crossed this stuff will work, Have you heard of it is head likely to be cracked , shows over 200000 kilometres on clock,is this about life of head on 1992/3 Surf
      Be glad of comments
      Adrian Ash
      A J Ashcroft
