Hi from a Newbie.
Had my HiLux for about 6 years and no real problems in all that time. One Radiator about 3 years ago and timing belt about a year ago. Both I did. Car has done about 250000kms of which we've done about 80 to 100 thou. Car had a new engine fitted in Japan just prior to it coming over - but probably they still used the old pump and electronics???????
Anyway, had a blown tyre on the M11 two weeks ago at midnight on the M11 and after semi flattening the batteries changing the wheel while also trying to protect myself from juggernaughts passing at very high speed only a few feet away. In the end I had to have the AA get me home because the Alarm had failed off and they couldn't reset it.
Since then I have had to have the Alarm replaced and now I have black smoke from the exhaust under medium to heavy throttle or steep hills. Have taken it to two specialists and am told finally that it is the ECU because the ECU is not registering problems that they put on the car. Presumeably they disconnect a few sensors and expect the ECU to register the "failure" when they do the diagnostics. Both specialists said the EGR was not a problem.
Incedentally, the car starts fine, runs actually a bit better than before and top speed is definately higher. Tick-over is a bit lumpier. But the Auto Box still seems to change at the right times and the Turbo likewise seems to be operating as before - or even a little better. But fuel consumption is noticeably worse. However, the black smoke does seem to be gradually coming less now after maybe 100 miles or so and a few reasonably long runs - or maybe I'm just getting better at controlling it????
So - a couple of quick questions.
1. When the AA disconnected the batteries trying to reset the alarm, they presumeably also inadvertantly reset the Fuel ECU. Anyone know how long will the ECU take to re-learn the correct settings?
2. Is there anywhere I can get hold of a wiring diagram - I don't trust my various Haynes / Chiltern manuals?
3. Is the ECU a reasonably easy part to source in the UK - or is it rarer than rocking horse droppings and cost the national debt?
4. Is there anyway this could be connected to my AirCon not blowing cold air?
5. I have tried the redex "cure" - but it was in a full tank of fuel. No apparent difference - but is it worth repeating the dose??
Finally, I am a retired electronics engineer (not automotive I have to stress) so not a complete muppit - just feel like one is all. If it were not for the MOT being due in two days I'd leave it for a while to see what might happen "naturally" - but no choice - it won't pass an MOT like it is currently.
Clear moral in all this is don't turn your engine off and leave the lights on - nomatter what the excuse!!!!!!!!
Many thanks - any replies gratfully accepted - even rude and uncomplimentary ones - provided they're funny.
Oh! - and a 3.0 Litre ForeRunner backbox and resonator fit the Surf fine - you just have to fabricate an extension piece on the front to make up the 5 or 6 inches difference. That's only if you can't get hold of the correct one of course.
jon
jon
