Clunk when turning
  • Clunk when turning
    I have identified the problem, but do not know what it is called, and can't find the camera.
    2.4 93 surf
    just behind the drivers side wheel is some form of ball joint, a rod comes from the rear of the vehicle and bends behind the wheel and connects onto a ball joint that then goes vertically down and connects to the wishbone area. The rubber bushes have all degraded.
    Anyone got a suspension diagram, or know what its called, is it safe to drive until I can get it done.
    Thanks again to all
    Tim
    2.4 93 surf
    Thanks again to all
    Tim
    Hi Tim
    This is the Stabiliser Bar Link.There is one each side.The rubber bushes at bottom are replaceable.If the top Ball Joint is worn then this is non repairable.Only available from Toyota down here as they are different to other Aussie Hi- lux vehicles which have bushes top and bottom.I need new ones as well.Best to replace both at same time.Not dangerous to drive like this but may cause more damage.
    Neville
      Clunk when turning
      Thanks Nevelle, managed to get a photo
      is this the bit you are describing.
      Thanks Tim
        Yeah, its the antiroll bar link.
        Toyota should be able to supply a bush kit for a 4Runner, or try Milners or Roughtrax
        Undo the link from the sway bar if it bothers you, or leave it be, won't cause any harm, it'll just slid up and down the hole.
          No dont go with Milners one, the kit doesnt have the proper vertical bolt with the ball joint at the top, their bolt is a simple bolt and is probably a minor difference in the spec of a US runner and a surf.
            Just checked a 4Runner rear bar I have in the garage, has the same ball joint, so a Toy Dealer UK 4Runner would be correct.
              Hello all
              I've been away all week, thanks to those who replied, good advice as ever.
              Tim
