i have just got a surf 2.4 and it is under powerd the turbo light doesnt come onand i think its over fueling i have checked all pipes and all seem ok i hope someone can help
surf 2.4
A hello or good evening would be nice.
Anyhoo, welcome on board, enjoy your stay. Have a look here for your problem...
http://www.hiluxsurf.co.uk/forums/sh...59&postcount=6
We need to know what year 2.4 you have, fill in the details under your username.
Low or lack of turbo boost is usually caused by lack of vacuum either from a faulty pressure sensor or a detatched/split/missing vacuum line.
Is the air filter clean? Dirty or restricted air filter will cause poor performace and unburnt fuel.
The pressure sensor is on the passenger side inner wing next to the power steering fluid reservoir, make sure the vacumm lines are connected to it and not dangling down somewhere.
Can you upload photos of your engine on here?
2.4 surf efi no power
goodevening everyone i have checked everything and i know its efi i found a 2 pin connector in the pump area with a white and red wire with noware to go maby there is something missing off pump i would be greatfull for advice or a wiring diagram cheers
