finally got me surf back together again and no leaks lol BUT went out on a run today and noticed od light flashing and wont jump into top gear(auto box)....not done owt with the box just changed engines?????????????
auto box playing up
No leaks now, you mean. What was the original leak caused by after you initially changed the engine?Originally posted by arron View Postfinally got me surf back together again and no leaks lol BUT went out on a run today and noticed od light flashing and wont jump into top gear(auto box)....not done owt with the box just changed engines?????????????
how do i do a diag check ???? ill try batteries and check terminals tomorrow,..thanks arron,,.Originally posted by stormforce View Postcheck all connections and make sure eveything is clean aswell.Do a diag check and see if that gives anything.Disconnect the batteries and see if that cures it,If needed i have got 2.4 ecus here
yes lol i originally put engine in with torque convertor attached to engineOriginally posted by MattF View PostNo leaks now, you mean. What was the original leak caused by after you initially changed the engine?
got in home to find it dripping lots of atf oil,,,engine back out new seal fitted to g box and put the convertor onto g box then fitted engine ,..now no leaks lol,..
