Uplug the gear selector multi-plug on the driver's side of the transmission and leave it disconnected. Then go for a test drive to see if you get all gears shifting manually. This will determine if it's a transmission or electrical fault.
Also, make sure the kick-down cable is slack and not under tension at the throttle body.
