Need some advice! (nothing new there) Surf 2.4 head gaskett cracked so had it sorted, but on return of the car there is one hell of a piston knocking, timing out type noiseand the engine check light on constantly combined with a lack of power. Took it back to garage where I'm told its the crank position sensor which is located in the deisel pump which had not been touched during the engine rebuild and that they want a further £500 to sort it out. Excuse my ignorance of all things mechanical but seems a tad suspect to me but then my knoledgre of all things atuo motive is hopeless and it may be just bad luck. any one got any thoughts ?
