hello all! got into a bit of bother with trying to put the orginal steering wheel back on to the surf. the pic shows what i assume is an extension piece from the steering shaft to fix the 'nice wooden' steering wheel to.
questio for the audiance is if anyone has taken the original wheel off and put this extension piece on how do you get if off
( i have unscrewed the nut off the shaft)
thanks
thanks
didnt know if could use WD40 on it or that would be even worse?? will try giving it a harder pull! or if that fails take to mates garage!
