Rear Seat Belts
  • Rear Seat Belts
    Hi,
    As anyone had problems with their rear seat belts not retracting, that is they can't pull out or in.
    Neil
    no-one that i know of has had that on the forum mate
      have seen this on other toyotas after a window has been busted... the smallest shard of glass can lock up the mechanism.
      the retract/lock mech is normally covered in clear plastic so you can see what it's doing... but you'll need to get it out first.
      [FONT=Trebuchet MS][B][SIZE=2]1993 SSR-X 2.4TD[/SIZE][/B][/FONT]
        I had that problem with the rear n/s seatbelt last summer. I eventually freed it by parking on the level and giving the bottom inside of the door post a good thump with my fist, while pulling sharply on the belt and then letting go. It has been OK ever since. I have had inertia reel belts do this on other cars too.
        It's only a hobby!
          Originally posted by neil_surf
          Hi,
          Neil
          Not me, all my lap belts retract fine.
          My 4x4
          My choice
          Back off
            It may be that the locking mechanism has jammed, you can disassemble them(which also allows you to retension the retraction spring, good for older surfs where it tends to get sloppy)
            see here for details: http://www.4x4wire.com/toyota/minutemods/seatbelt/
            Life is not a dress rehearsal
            1996 3.0 SSR-G 5-speed
            (Auto's are for the indecisive!!)
              Seat Belts
              Thanks Everyone for your help.
              Neil
