Hi guys,
Need a little help on this one... Got in my 2.4 LTE surf this morning after leaving her to stand overnight, warmed up the glows and and tried to crank over...
All I got was a clunk and the engine check light, dud batt light and seat belt light up on the dash... Took the key out and popped the bonnet to check connections and the engine starts to crank on its own accord very slowly. Earth points started smoking and before I could get to the fuses or battery negative, the power steering hose melted totally (off the pump) and spewed oil everywhere.
Checked all obvious earth points and still no luck. Any ideas what could be causing this?
The odd thing is, it only does this if the right hand battery is hooked up. Just get a dry clicking sound if i disconnect it and drop the right hand one in.
Only had the truck a year and still getting me head round it, so any help would be greatfully recieved!
Alex
Alex
