Good morning.
After searching for ages i have found nothing regarding this even in the service manuals ive found, so............Could somebody tell me please.
is the push rod from the clutch slave cylinder ment to still be in contact with the clutch lever when the clutch pedal is in the up position???, i can push the lever and push rod back into the cylinder about 10-15 mm with my fingers!
There is a small amount of free play at the pedal(as it should be)
i have bled the clutch but im thinking like there must be air or pressure still in the line to cause the push rod to remain out a little??.
Just to my mind i would have thought the push rod should be all the way back in the cylinder and allowing the clutch lever to be 'free' and under no pressure whatsoever.
or is this its normal resting place.
, i just wasn't sure how much pressure the slave piston should be pressing against the clutch lever when at rest.
oh Rolloxs! lol
