Hi everyone.
Update on my surfs progress.
I placed a thread named 'major head story' but in brief here is the first part of the story:
70mph down A9 after fitting new head from UK Cylinder heads (Head Centre), new thermo, new rad etc.
Loud ticking/knocking noise, smoke out back(blue) and eventual power loss.
Towed back to garage that fitted head. Head removed and sent to Head centre who said it was warped, the injector chambers were loose and moveable.
Head centre refused warranty but did replace injector chambers for oversize ones and apparently skimmed the head. They sent it back to me.
Part 2
Head was refitted by garage, connected enough to get going and test the head. Same noise.
Garage then embarked on a bottom end strip down.
Big ends fine, crankshaft fine, bores fine, pistons fine including rings and tops.Small ends fine. Independant engineer looked over bottom end, he said he was 'confused not to find anything' and said it all 'looked like new'.
Part 3
Garage went to head next, they have checked the cam-fine, the injector chambers are rigid.
They said that they have only two things to check- the valves and seats and the injector pump. They are doing this tomorrow.
They said 'if we don't find anything there we are stumped'.
Sorry to be so long winded but thought if someone might have an opinion its worth writing it all down.
I know its impossible to diagnose anything remote, but any advice would be really welcome. Would the seats or injection pump give this sort of noise/problem?
Thanks for your help. I am going to subscibe to the forum, as I feel its a vital source of help for surf owners.
How much is it? and how do I do it?
cheers
Ronnie(aka Lightwallet.)
Part 2
Part 3
cheers
