Throttle Position Sensor
Thats lt-e nev recons the lt ones are differentOriginally posted by BUSHWHACKER View Post
i am trolling through matts electrical download section section now, but will have to give up soonLast edited by BioHazard; 26 February 2009, 19:36.' You've arrived on a rather special night. It's one of the master's affairs.'
From here:
http://www.troublecodes.net/Toyota/
and here:
http://www.off-road.com/toyota/tech/codes/
It would seem that they are the same on both models. Personally, I still think that it is unlikely that the TPS and temperature sensor have failed simultaneously and that big mess of wires is the culprit.
the temp sensor for the ecu is under the inlet manifold, the temp sensor for the gauge is on the thermostat housing as my previos postOriginally posted by NiftyNev View PostThey sure are.
Stop looking for the Temperature Sensor on the thermostat housing because, if you have one it won't be there. I would have thought that someone on here would know where it is by now. Your model and frame numbers will help identify your vehicle. If you have a latter 2L-T you will have a temperature sensor and a TPS along with an emissions control computer. The temperature sensor will be in the block under the manifold, above the starter roughly between cylinder three and four. The TPS could be on the fuel pump. If earlier it will not have them. Diagnostic codes between the 2L-T and 2L-TE are very different.
NevJAP4X4PART ¬ THE BIGGEST SURF BREAKER IN THE UK ¬
