took my injectors apart the other day and the washers between the top half and bottom half have all broken,can i just get any fiber washer or does it have too be the right ones ,if so where from please .ta smithy
injectors?????
Been there done that .................. i always had one that leaked afterwards , you will need copper crush washers as well , The best bet would give them to a diesel specialist and get then properly refurbished .Originally posted by smithybluebus View Posttook my injectors apart the other day and the washers between the top half and bottom half have all broken,can i just get any fiber washer or does it have too be the right ones ,if so where from please .ta smithy
Diesel Bob does a good service
The link does not show the fiber washer but gives the crush washer part no
http://www.toyodiy.com/parts/p_J_199...KPQT_2201.htmlLast edited by BioHazard; 22 February 2009, 10:21.' You've arrived on a rather special night. It's one of the master's affairs.'
If you are talking about the washer that sets the pressure and on top of the spring, then you will need the correct part and there are numerous thicknesses. These are used to set the injector opening pressure which needs specialist equipment.
23631 in the linked diagram.
Nev
