which is number 1 cylinder
  • which is number 1 cylinder
    ive stripped every thing off the top of the engine ready for cylinder head removal.not sure which is no 1 cylinderand also cant undo crankshaft pully
    any advice most welcome
    No. 1 cylinder is the cam belt end, when I removed my front pulley I used the bolt holes in the pulley, drilled a bit of angle which was long enough to rest on the ground when bolted to pulley then undid the bolt, I then drilled another shorter bit and bolted this on the pulley with the loosened bolt in the crank, then undid the crank bolt up against the angle which pushed the pulley off. Does that make any sence?
      yes sounds good .does the crank bolt undo anticlock wise like normal
      thanks
        Or you can use the tensioner bracket, works well.
        My 4x4
        My choice
        Back off
          Yup it's a normal thread
            its all off now
            sorry forgot to say thanks earlier
