OK I've cruised the forums but I'm hoping someone somewhere can point me in the right direction here.
My 93 Surf was consistenly returning around 20/22 mpg for months. All usual servicing done i.e fuel filter, air filter and oil change all done about 2 months ago and everything as it should be.
Now over the last 2 weeks or so the mpg is down to about 15. There is no power difference and no smoke and it's doing the same type of motoring every day.
There appears to be no leaks as I've been under and over it with a tooth comb. The only thing I've noticed over the last month of really cold weather is that it's a bit smokier on start up but is sweet as a nut after 30 seconds or so. So, anyone got a clue as to where else to look.
Any advice will be greatly appreciated.
