hi all, i have a 1997 2.4 td, does anyone know how to remove the timing belt cog off of the crank????and does anyone know where to get a haynes manual????thanks
confused??
Pull the cog off with a puller? Haynes don't do a Surf manual, but if it's just any old manual you want (you didn't say if it was a Surf one you wanted) Halfords keep a large stock.Originally posted by zem_41 View Posthi all, i have a 1997 2.4 td, does anyone know how to remove the timing belt cog off of the crank????and does anyone know where to get a haynes manual????thanksDo you know that, with a 50 character limit, it's
He removed the *cog* with a Stanley knife?Originally posted by The Hornet View PostWith a stanley knife. How should I know, I'm not a mechanic.
Probably made it up, as do most specialists. I reckon you could do it with a nail file though. It must be a simple job cos I have seen the pulleys inside the engine bay!
i asked how you could have a 1997 2.4.........then noticed it was a pick up...must read vehicle detailsOriginally posted by Albannach View PostMr GWH, I do believe you deleted a post just there...
So I deleted my reply.
anyhow im not sure if the engine and pulley arrangement are the same for a later 2.4Non intercooled nothing.
I noticed that pretty late on too!Originally posted by gwh200 View Posti asked how you could have a 1997 2.4.........then noticed it was a pick up...must read vehicle details
Doesn't matter, you can apparently take it off with a Stanley knife (possibly even a nail file)...Originally posted by gwh200 View Postanyhow im not sure if the engine and pulley arrangement are the same for a later 2.4Do you know that, with a 50 character limit, it's
would it be a reference to the harmonic balancer having debonded ??Originally posted by Albannach View PostDoesn't matter, you can apparently take it off with a Stanley knife (possibly even a nail file)...
anyhow, if its the same as an older 2.4, undo the pulley nut,get the key out and use a puller....do a search on 2.4 cambelt change..there is loads of info on how to do it.Non intercooled nothing.
teeth:
