hi my rear window goes all the way down but only goes half way up do i need a new motor or can it be greased or something
rear window sticking
Need more information. What does it do when it stops going up? Does it make a noise or just stop?Originally posted by grafter View Posthi my rear window goes all the way down but only goes half way up do i need a new motor or can it be greased or somethingDo you know that, with a 50 character limit, it's
Mine is especially slow and hesitant in Cold weather so I leave it closed mostly,
which isn't perhaps terribly helpful is it actually.
This is a recurring question on here so you might find the numerous subjects that come up in search helpful as its a little quiet here this evening
Have you tried spraying silicon spray in the runners ?Originally posted by henry F View PostMine is especially slow and hesitant in Cold weather so I leave it closed mostly,
This is a recurring question on here so you might find the numerous subjects that come up in search helpful as its a little quiet here this eveningLook out Eastbourne, the Pandas are coming !
Remove the trim panel and plastic sheet.
The motor is tiny as the mechanism relies on spring assist to counterbalance the weight of the glass therefore it doesn't take much friction for the mechanism to jam. Give the entire mechanism a good spray with spray grease - it's excellent stuff as it penetrates well.
http://www.hiluxsurf.co.uk/forums/sh...ighlight=fixed
try that mateam not die lex sick its you that cant read mate
