trying too take cylinder head off my 2.4 turbo jreg surf.1st i cant see the lower nuts too rear of the inlet manifold let alone undo them and found out the lower nut on pipe that goes round the back of head from exhaust too inlet manifold the nut is rounded off just great huh? how do you get too udo the inlet nuts and bolts?? i took off filter parts on top of inlet manifold and injectors too still no joy underneath,any helps plzzzzzzzzzzzzzzzzzzzzzzzzzzzz and any other tips please before i beat it with a stick
help
Have always left the manifolds in place on the 5 or 6 I have done, yeah nuts are a little awkward to get to. If its rounded off as said then you will need to take the whole lot off to get better access to the rounded nutSay not always what you know, but always know what you say.
My 4x4
My choice
Back off
