Hi guys. I noticed the other day that the wee wheel in the middle that the air con belt rests on isn't turning. Is there an adjustment for it. Hope you know what i'm talking about. Thanks in advance regards garry
Wheel not turning
If it's the small wheel above the belt you're talking about, it doesn't turn all the time. From what I can gather, it's only there to take up the momentary slack/whip that happens to the belt when the AC clutch engages.Originally posted by gaffer39 View PostHi guys. I noticed the other day that the wee wheel in the middle that the air con belt rests on isn't turning. Is there an adjustment for it. Hope you know what i'm talking about. Thanks in advance regards garryDo you know that, with a 50 character limit, it's
Thanks Guys Will have a look in the morning and put a/c on to see what happens. I was under the impression it spun all the time against the belt, but will let you know .Originally posted by Albannach View PostIf it's the small wheel above the belt you're talking about, it doesn't turn all the time. From what I can gather, it's only there to take up the momentary slack/whip that happens to the belt when the AC clutch engages.
It doesn't spin all the time, no need to let me know. And you'll likely see nothing when you put the air con on. As I said it's apparently only there to take up any whip in the belt when the AC kicks in.Originally posted by gaffer39 View PostThanks Guys Will have a look in the morning and put a/c on to see what happens. I was under the impression it spun all the time against the belt, but will let you know .Do you know that, with a 50 character limit, it's
