seems my heating is not working, where should i begin to sortthis.
the fan works, the AC needs repressurising.
 i also have no heaters cold air only.just had new belts fitted and since then i.ve heard a slit grinding noise.my machanics flushed the matrix out all fine all pipes are fine and getting hot and heater valve ok as well.sounds like grinding noise coming from waterpump so having new one fitted friday and hope to get some heat in the old beast cause its ###### cold.
