Roy,
Did you fit new or reconditioned injectors? If new, where did you get them from?
I did an ECU diagnostic check and fault 7 (Throttle Position Sensor) came up, but I cleared that and then had the code 1 (OK). The TPS was probably an old fault from when they put the head on or something, but I will keep an eye on the faults as the ECU light was not illuminated to indicate a fault had been logged - maybe it only lights with a persistant fault?!.
Mine's definitely getting progressively worse and that could be injectors gumming up - I now need to wait for the glow plug beep before attempting to start - it used to start perfectly when the glow lamp when out (approx 1-2s after turning ignition on).
Cheers,
Jonathan
Cheers,
Jonathan
