I'm having a bit of trouble with my rear window, it wont de-mist. I have checked to see whether there is power to the electrical connectors on the window and there is a very faint power signal. I was using a circuit tester with a light and the light wasn't very bright at all. anyone else had any problems with the rear window. Both my KZN and LN-130 have no de mist?
No rear De-mist
I one had the very same problem. It turned out to be the cables that run to the screen from the control box.
Remove the back carpet panel and the metal cover. You'll then have to shut the tailgate and send the window up about 1/2 way.
The cables run in a plastic truking but mine had flexed so much one had brokenBring me the head of a treehugger
