It has been a while since I posted and I have researched on the forum with no definitive answer.
I have excessive oil in my intake before and after the turbo. This is a new problem that I noticed after I had installed a new Injector Pump. It may not be the reason but I have noticed it since then.
I seem to be burning too much oil as well.
I have lots of black smoke when I accelerate, with turbo boosting. If I gently touch pedal then it will not smoke.
Truck seems to run good, no lack of power and turbo pulls good on highway speed.
I do need injectors and glow plugs and will do them soon. I am concerned about the oil though.
If it is excessive blow by is there anything that can be done?
If it is the turbo could it cause oil in pipes before and after?
Any ideas or things I can try?
Thanks much
Frank
Thanks much
Frank
