First off I'd like to thank everyone who's helped me on this forum. I've had nothing but problems with my surf and have posted here a few times. Had nothing but great help from everyone! Thanks!
Now... another issue. Here's the back story to shed some light.
I had a bunch of work done on it. New rad, new water pump, new thermostat, new therm. housing and timing done. A week later the head went on my 1991 Hilux Surf 2.4L, I bought a 3.0L head from Rocky Mountain Imports in BC (he sells the good 3L heads) and got the mechanic to install everything.
Right after it ran terrible. I took it to another mechanic and he did a pressure test at 250psi and no faults. He did find the timing belt tensioner had never been reset after the last installation causing it to slip, so put the timing back in line. It has gotten a little better and once it heated up it seems to be "decent" at best but it drives. When starting in the morning it pushes alot of smoke, not 1min worth but about 10-15mins of smoke. It covers the apartment parking lot. I've replaced the glow plugs and that hasn't made it any better. The only thing I can think of is to take the fuel injectors out and get them looked at. Would the engine start rough if an injector wasn't spraying properly? Once the engines temperature rises the car runs smoother but is still fairly gutless.
Any suggestions on this? Oh, and my heater isn't working. I'm not sure if that has anything to do with anything but thought I should mention it.
Thanks again for everything!!!
Cheers,
Mike
Cheers,
Mike
