Just a thought, i know it is possible but would a engine block crack between the bores and the water jacket, my head has gone, i thing but could it be the engine, im sure i read that Stevo said they don't go but i could be wrong, does anyone know of one going for sure.
Engine block cracked ? is it posible
I can't be arsed looking through all the posts in your other threads about this issue. The water has to go somewhere, if it's not coming out of the exhaust or anywhere else externally, it's in your oil. Have you checked that?Do you know that, with a 50 character limit, it's
In my case its either the head, gasket or block, by the look of it, my question was, is it posible that it is the block, just to rule things out, from what i can remember Stevo said the blocks don't go on surfs, yet some say it could be the block, so im wondering if anyone has had one go on them.Originally posted by Albannach View PostI can't be arsed looking through all the posts in your other threads about this issue. The water has to go somewhere, if it's not coming out of the exhaust or anywhere else externally, it's in your oil. Have you checked that?Roy
When ya stop having fun, Ya start getting old
Blocks can crack.Originally posted by roylittle0 View PostIn my case its either the head, gasket or block, by the look of it, my question was, is it posible that it is the block, just to rule things out, from what i can remember Stevo said the blocks don't go on surfs, yet some say it could be the block, so im wondering if anyone has had one go on them.
You didn't answer my question though. Have you checkd the oil?Do you know that, with a 50 character limit, it's
mine was when i got it.it had a smallish crack between no's 2 and 3Originally posted by roylittle0 View PostIn my case its either the head, gasket or block, by the look of it, my question was, is it posible that it is the block, just to rule things out, from what i can remember Stevo said the blocks don't go on surfs, yet some say it could be the block, so im wondering if anyone has had one go on them.Non intercooled nothing.
on one of the 3.0l's i had here Roy.I fitted another head and the truck was running perfect apart from p155ing out oil.I did everything you have and couldn't find what the problem was.Sledge came down and we were going to drop the gearbox and put in a new crank shaft seal but we notice the oil was to far up the engine to be that seal.We came to the conclusion that the block had to of cracked and it only opened up when under pressure.
It looked as if the block cracked on the back o/s where the head meets the block but just a bit lower down.I think there is an oil way right on that back corner of the block which wenthttps://www.facebook.com/groups/henpals/
