Couple questions for you guys.
I have a 91 surf, 2.4LTD 4wd
Snapped a front wheel stud (friggin bad day, went from bad to worse)
I was taking the front wheels off to check my pad life (haven't checked since I purchased the vehicle)
Passenger side rim came off no problems, the problem started on the driver side.
Wheel nuts came off no problem, then tried to take the wheel off. I kicked, smashed ripped, pulled. I tried everything to get this friggin thing off.
I had to get to somewhere, and I was running out of time, so I just put the rims back on. While torquing the nuts back on, I snapped a wheel stud!
What exactly is the procedure to put a new one on?
When I go to take the rims off, whats the trick to getting the rim off if its stuck on like a #######?
