hi guys,
i'm about to get this particular Surf. There's one problem that's bothering me. here it goes....
I have test drived other surfs and if i remember correctly, the "4WD" light will come on when i press the 4WD button at the side of the 4WD gearstick and the light will go off when i release it. But when i test drived the surf i'm thinking of getting few days back, the light will not come on when i press the button! I asked a mechanic and was told that it was probably due to the some leak in the vacuum in the transmission. The mechanic also said that that the car might not have been engaged in 4WD for a long time. And will be ok after engaging it after a few more times. True enough, after the mechanic engaged it a few more times, the light did go on and off at the flick of the button. What the mechanic said, is that true? Are there other reasons? The owner did claim that she hasn't put it in 4WD for a long time.
Need advice on this. Would love to get the car soon if there are no major issues.
Thanx
Monkey
Thanx
Monkey
