Just thought I'd post this as I couldn't find a definitive guide on this relatively simple job:-
Model: LN130 2.4 TD (AUTO) RHD
Work Done:- Remove and replace exhaust front pipe genuine Toyota off/on
Elapsed time:- 45mins
Notes: Genuine Toyota AUTO down pipe has heatshield surrounding the top flex joint and this makes the job somewhat harder as access is limited
1) Under drivers side of vehicle (offside)
2) Drivers side (offside) wheelarch
3) Under bonnet
4) Under passenger side (nearside)
5) Under drivers side of vehicle (offside)
6) Have Pint/Cuppa and admire new pipe and gaskets
7) Fitting the new one is essentially the reversal of removal - use new gaskets and jointing compound on the front/mid joint (ensure old gasket is not left on the mid section. I find it best to leave all fitting loose until pipe is in position then tighten.
Hope this helps!
- Remove two heatshields one attached to floor pan (2xnut - 10mm socket) and one attached to chassis rail (3xbolt - 12mm socket).
- Remove two bolts (17mm socket) securing exhaust bracket to g/box housing - long extension required for upper.
- Remove inner wheelarch access plate.
- Locate exhaust pipe clamp which clamps exhaust to the gearbox bracket of which the two bolts were removed in 1) above. Undo the single bolt on the clamp - access is limited as bolt points down TSK TSK! Withdraw the g/box bracket from under the car.
3) Under bonnet
- Remove 4 heatshields from around turbo, brake vac and down pipe.
- DO NOT attempt to remove down pipe from turbo elbow in situ. It's much easier to remove the down pipe with elbow attached - remove 4 nuts attaching elbow to turbo body.
- Remove two BOLTS (14mm socket) securing front pipe to mid pipe (nuts are welded to mid pipe flange) - expect these to be corroded - soak well in releasing fluid and take it easy.
- Remove bolt (12mm socket) securing front pipe to body bracket - WARNING front exhaust is now free and liable to drop!
- Manouvre pipe from under the car but note it's pretty tight between chassis rail and g/box but it does fit if g/box bracket and 2 x heatshields have been removed.
Hope this helps!
