Has anyone got a picture of the 2.4 engine showing the cam belt and timing marks, hopefully before tomorrow when i have anothe go at setting it up, should the marks be spot on middle ond are they all at the 12 o'clock position.
2.4 Timing marks
 They are NOT all at 12 o'clock! Search for pics, there are some on here.Originally posted by roylittle0 View PostHas anyone got a picture of the 2.4 engine showing the cam belt and timing marks, hopefully before tomorrow when i have anothe go at setting it up, should the marks be spot on middle ond are they all at the 12 o'clock position.Do you know that, with a 50 character limit, it's
 Here we go: http://toyotasurf.asn.au/techsite/timingbelt.htm
 If stuff doesn't line up first time, turn the engine by hand at least one full revolution (2 crank revs) and re-check. If it doesn't line up, re-do it.Do you know that, with a 50 character limit, it's
 Sorry, like Sledge said, do it from the crank pulley. And the marks will alays line up perfectly (after a couple of revs by hand) if the timing is right, if they do not all line up 100% perfectly, re-do the timing until they do!Do you know that, with a 50 character limit, it's
