Gentlefolk,
as you may or may not know... brakes have been a minor obsession of mine for some considerable time.
Perhaps because I understand the braking system well enough, perhaps because I haven't got a clue.
Brake pedal is applied, piston moves in master cylinder, fluid is forced around the system, brake pads are applied to the discs or drums.
Simple enough...
We have vaccum assist to apply more pressure than some of us could manage with one foot... and bob is your sisters husband.
So, as we add bits to our toys, they get heavier... as we increase the size of our tyres... etc. etc.... we need stronger brakes... and so it begins.
One of the popular mods is to fit an 80 series master cyclinder... 1" bore (apparently)... popular in the states.... note, the 80 series master cyclinder exits out on the left hand side looking forward. Great in a left hand drive vehicle, as your heat shield would be on the right... not so good on a right hand drive vehicle, as it interferes with the heat shield... (on a 2.4) [ anyone want a brand new 80 series master cylinder...? ]
So, what can we do with our right hookers... well, the 3rd gen master cylinder is handed too... pipes exit out on the right, for a right hand drive... and the bore is half way between a 2nd gen MC and an 80 series... Its also a perfect fit, everything lines up.
Braided brake hoses, take the slack out. Job should be a good 'un... should be...
so why won't the system pressurize... first press goes all the way to the floor... second press is rock hard... truck nearly stands up on its front wheels.
I have tried everything, short of changing the hard lines... everything is new... a spanner in the works was a cracked caliper, weeping ever so slightly... yet another one... (Barry at Roughtrax is an absolute star, customer service rocks with those guys)
Can anyone suggest anything at all... I am about to set fire to the truck...
And if anyone comes along with a sensible offer, its thiers... I'll even put a bottle of bubbly in the back.
Simple enough...
