Trying to tack down where this oil is coming from and have noticed other things, would like your opinions please
Took the air intake to the throttle body off adn find lots of oil sitting at the bottom of the pipe
More around the TB accelerator wire assembly
Seems to be a leak from this part on the drive shaft, is this right.
Here you can see some leaking from the gasket it would seem or maybe from the pipe above as this seems heavily oiled (ie the source)
More oil
Whats this overflow looking pipe thing
More oil
