Does this bit need greasing
    would it be advisable to remove the drive shaft to grease it, or leave it in situ.
      Pah, you should have seen my UJ (or remians of) at Run To The Sun. Now that was knackered.
      Hold my beer and watch this
        You can grease in situ but i would recomend getting a grease gun with a flexable hose which will make your life a bit easyer. you might wanna pick up a few spaire grease nipples too. cos i fond i had just plain bolts in some of my greaseing points. good luck and rember to give the ujs a good push and pull and if any feel loose or kind of klunky you might be replacing them soon. they can get really gunked up inside and not get grease everywhere it needs to be.
        have fun, oh and wear overalls or old clothes it can get messy!
          ta
            has anyone got the part numbers for replacement grease nipples.
              Just go to your local factors or ironmongers and get some M6 45degree and 90degree nipples.
                ta
