Does this bit need greasing
  • Does this bit need greasing
    Had time to look around the lux today, Does this bit on the driveshaft need greasing up.
    Hell yeah, after an acid dip though!!!!
      Sand blasting wouldn't go a miss
      Roy
      When ya stop having fun, Ya start getting old
        the previous owner lived in brighton and so a lot of sea air has been breathing on this one.
        any particular grease to use, i assume it should be applied with a grease gun ?
          Hi,
          If you go to the file download section of this site you will find a greasing diagram which shows you exactly what you need.
          Thanks to whoever uploaded it.
          Brian
          Thanks,
          Brian
            thanks again
              would you know of any particular brand of grease to use. would halfrauds have these items.
                Any Lithium based grease will be fine.
                  cool, so i wont need two types as per the greasing scheadule, http://www.toyotasurf.asn.au/techsit...g%20Points.pdf
                    Jeez that looks minging!!!
                    Mine looked fine externally, and seemed to be taking grease OK, but inside it looked like this...
                      Well done Andy, you have done a better job of knackering a UJ than I did
                        When I noticed the problem, I was 150 miles from home, and had no choice but to drive home. Probably why it was so shafted! It was too hot to touch!
                          Blimey, I really should check mine after seeing those, especially with the extra oomph exerted on them.
                            ouch
                              Re
                              Absolute pain in the arse to grease all the yokes, cardan joints etc. but WELL worth doing!
                              I hadn't done mine in about 3 years (I don't off road, only tarmac!).
                              When I done them recently I made sure they were done really well (nipples cleaned and stuffed full of grease)
                              The Surf is a LOT quieter and smoother now!
                              I found this amazing!
                              A couple of quids worth of grease!
                              You may as well do your ball joints as well, after seeing that pic gawd knows what state they are in!
                              G
