Hi,
I have a 2.4 auto ssr-g which has very recently started to "slip" when moving off. I accelerate, the engine revs then the gear kicks in with a jolt and the truck moves off.
Is this knackered or could it just be the oil level in the gear box (I can't check at the moment as I am not at home). Also I have been told you check the gearbox oil level with the engine running. Is this correct?
If it is knackered, how specialised a job is replacing it?
Brian
Brian
