On a serious note - when I bought the truck it had a serious vibration thoughout the whole truck that started at around 50mph but you could drive through it at about 55mph. It got worse and I put it in the garage. Got it back and they said the only thing they coul find was a loose bolt or two on driveshaft. Vibration cured - now nearly 2 years later it has started again - had all the bolts checked an they are fine! Anyone come across this before?
