ok i have just replaced the seal on the valve under the 4 injector pipes, the one with the wire coming out and grey round plug on end.
it is still leaking possably cos the seal is too small,
someone mentioned in another post about puting auto trans oil in the fuel to swell the seal, will this work on viton, alternatively is it possable to stop it leaking any other way, this is the third time i have repaired it and its been through 2 pumps. i will not do it again, if there is nothing else that can be done accept take it out then i am done with this car, i have no garage no driveway just the carpark behind my house and i have given this car as much knuckle skin as it gonna get, if there is ANY way to stop this leak without the pump out PLEASE let me know.
is there possably any sealant i can use ie unscrew it squirt and tighten
