hi, read through the site but no obvious answer.
I have a 2lt engine with the mech pump. there seems to be a lot of fuel burnt up with smoke and a slight knocking noise after a recent repair. I checked the timing belt and the marks line up fine (belt teeth are quite large - ab 5 mil - so if a tooth was out would be obvious right?)
Is there any other way to advance or retard the fuel pump? The bolt holes on the pump don't seem to be elongated to allow me to do this.
Any ideas? - or maybe it's fixed and if you got the pulley right it should be fine?
Thanks a lot
Thanks a lot
