Hi Guys,
I'm a newbie and have read with great interest a lot of the posts on here.
Hope somebody can help with my problem.
I've recently bought a '92 surf 2.4TD ssr-x, I was told by previous owner it had been running on WVO.
I drove home in it for 45 miles or so with no problems.
I then added 20 litres WVO to 1/4 tank and started running, everything was fine for approx 5 miles stop start running. Then lost all power and engine check light came on and lost power, max speed dropped to approx 10 - 15 mph. I thought that maybe this was too much for the engine to take so added 1/4 tank diesel with the WVO. Still getting problems so checked this site for info. Did a fault code check and coming out with code 12, fuel pump TCV fault. I then changed the fuel filter, bled lines etc. same fault.
The fault only seems to appear after 5 - 10 mins running.
I then resorted to draining the fuel tank completely and refilling with 1/4 tank fresh diesel, fitted a new fuel filter and bled through lines. I also added some redex to try to clean the system out.
Still getting the same problem, everything ok on start up sounds really sweet, but after 5 mins running, can only reach 5 - 10 mph with engine check light on. Still giving code 12 after resetting ECU. (removing fuse for 30 secs. and disconnecting battery)
I've tried running with filler tank cap removed as i thought that maybe fuel tank breather had become blocked but to no avail.
When the problems start ie after 5-10 mins there is a lot of white smoke issuing from tail pipe which leads me to think fuel starvation, I'm pretty sure that it is whit smoke rather than steam hopefully discounting head/gasket probs.
Thank you all in advance for any replies which will be most welcome and i will revert with any further developments.
No conversion has been fitted for running on WVO, just been mixed in diesel tank.
